Datasheet Texas Instruments OPA2541AM-BI — Даташит
СерияOPA2541
МодельOPA2541AM-BI
Dual High Power Operational Amplifier datasheet
PDF, 155 Кб, Файл опубликован: 27 сен 2000
Операционные усилители HiVltg Hi-Current Op Amp
OPA2541AM-BI
OPA2541AM-BI
T-electron
OPA2541AM-BI
Электромеханические реле Hongfa – надежность и качество 19 января 2023
Package TypeZZ030
Industry STD TermZZ (BB)
JEDEC CodeO-MBCY-W
Рекомендуемая замена
ReplacementOPA2541AM
Replacement CodeS
Additional FeaturesN/A
Approx. Price (US$)206.80 | 1ku
АрхитектураFET
CMRR(Min)(dB)95
CMRR(Typ)(dB)106
GBW(Typ)(MHz)1.6
Input Bias Current(Max)(pA)50
Iq per channel(Max)(mA)25
Iq per channel(Typ)(mA)20
Number of Channels(#)2
Offset Drift(Typ)(uV/C)15
Operating Temperature Range(C)-40 to 125
-55 to 125
Output Current(Typ)(mA)7000
Package GroupTO-3
Package Size: mm2:W x L (PKG)8TO-3: 974 mm2: 25.4 x 38.35(TO-3)
Rail-to-RailNo
Slew Rate(Typ)(V/us)8
Total Supply Voltage(Max)(+5V=5, +/-5V=10)80
Total Supply Voltage(Min)(+5V=5, +/-5V=10)20
Vos (Offset Voltage @ 25C)(Max)(mV)1
RoHSНе совместим
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Tuning in Amplifiers
  • Mounting Considerations for TO-3 Packages
    PDF, 73 Кб, Файл опубликован: 27 сен 2000
    Proper mounting of TO-3 packages is required to assure rated performance and reliability. Although the procedures are simple, ignoring them can result in poor performance and catastrophic failure of the device.
  • Op Amp Performance Analysis
Серия: OPA2541 (5)
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
OPA2541AMBI, OPA2541AM BI
На английском языке: Datasheet Texas Instruments OPA2541AM-BI
