Datasheet Texas Instruments LM43602QDSUTQ1 — Даташит
СерияLM43602-Q1
МодельLM43602QDSUTQ1
Automotive Qualified SIMPLE SWITCHERВ® 3.5V to 36V, 2A Synchronous Step-Down Voltage Converter 16-SON -40 to 125
LM43602-Q1 SIMPLE SWITCHERВ® 3.5-V to 36-V, 2-A Synchronous Step-Down Voltage Converter datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 25 апр 2017
Электромеханические реле Hongfa – надежность и качество 19 января 2023
Pin16
Package TypeDSU
Package QTY250
Width (мм)4
Length (мм)5
Thickness (мм).9
Approx. Price (US$)2.07 | 1ku
Control ModeCurrent Mode
Duty Cycle(Max)(%)99
Iout(Max)(A)2
Iq(Typ)(mA)0.027
Operating Temperature Range(C)-40 to 125
Package GroupSON
RatingAutomotive
Regulated Outputs(#)1
Special FeaturesEnable
Frequency Synchronization
Light Load Efficiency
Power Good
Synchronous Rectification
Tracking
Switching Frequency(Max)(kHz)2200
Switching Frequency(Min)(kHz)200
ТипConverter
Vin(Max)(V)36
Vin(Min)(V)3.5
Vout(Max)(V)28
Vout(Min)(V)1
RoHSTBD
  • Evaluation Modules & Boards: LM43602PWPEVM
    LM43602 Synchronous Step-Down Converter Evaluation Module
  • Inverting Applications Made SIMPLE With LM4600x and LM4360x (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 20 фев 2015
    Weoftenrequirepowersourceswithnegativeoutputvoltages.Therearemanydifferentwaystoproduceanegativeoutputvoltagefromapositiveinputvoltage.Oneoptionisapolarity-invertingbuck-boostconverter.Theadvantagesofthistopologyarethatitrequireslowcomponentcountandthatitcanbebuiltwithstandardhigh-sideregulato
  • Thermal Design Made Simple With LM43603 and LM46002
    PDF, 535 Кб, Файл опубликован: 15 сен 2014
    This Application Report will walk through the thermal design of power supplies using the LM43603 and LM46002.In the process we will cover common tips and approximations to speed up your design.
  • Compensation Made SIMPLE With LM4360x, LM4600x
    PDF, 457 Кб, Файл опубликован: 29 июл 2014
    Compensating a DC-DC buck converter is challenging if the designer is not familiar with the loop control theory. To achieve a stable design under all corner and adverse conditions, the user must properly compensate the regulator. While DC-DC converters with external compensation provide flexibility, they increase complexity. The LM43600/1/2/3 and LM46000/1/2 are a family of Wide VIN, fully-synchro
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
На английском языке: Datasheet Texas Instruments LM43602QDSUTQ1
Публикации по теме
