Datasheet Texas Instruments OPA2244UAG4 — Даташит
Серия | OPA2244 |
Модель | OPA2244UAG4 |
Операционный усилитель MicroPower с однополярным питанием MicroAmplifier™ Series 8-SOIC
MicroPower Single-Supply Operational Amplifier MicroAmplifier Series datasheet
PDF, 1.2 Мб, Файл опубликован: 27 сен 2000
Купить OPA2244UAG4 на РадиоЛоцман.Цены — от 133 до 557 ₽ 14 предложений от 11 поставщиков OP Amp Dual GP ±18V/36V 8Pin SOIC Tube | |||
OPA2244UAG4 Texas Instruments | 133 ₽ | ||
OPA2244UAG4 Texas Instruments | 135 ₽ | ||
OPA2244UAG4 Texas Instruments | от 197 ₽ | ||
OPA2244UAG4 Texas Instruments | по запросу |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 75 |
Carrier | TUBE | TUBE |
Маркировка | 2244UA | OPA |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | N/A |
Архитектура | Bipolar |
CMRR(Min) | 72 дБ |
CMRR(Typ) | 98 дБ |
GBW(Typ) | 0.43 МГц |
Input Bias Current(Max) | 25000 pA |
Iq per channel(Max) | 0.05 мА |
Iq per channel(Typ) | 0.04 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 4 uV/C |
Output Current(Typ) | 12 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.1 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.2 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 22 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 1.5 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2244 (10)
