Datasheet Texas Instruments TLV2460QD — Даташит
Серия | TLV2460 |
Модель | TLV2460QD |
Одиночный, маломощный, Rail-to-Rail операционный усилитель ввода/вывода с отключением, 8-SOIC от -40 до 125
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.7 Мб, Версия: J, Файл опубликован: 29 фев 2004
6 предложений от 6 поставщиков General Purpose Amplifier 1 Circuit Rail-to-Rail 8-SOIC | |||
TLV2460QD Texas Instruments | 72 ₽ | ||
TLV2460QD Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Shutdown |
Approx. Price (US$) | 0.73 | 1ku |
Архитектура | Bipolar |
CMRR(Min)(dB) | 71 |
CMRR(Typ)(dB) | 85 |
GBW(Typ)(MHz) | 6.4 |
Input Bias Current(Max)(pA) | 14000 |
Iq per channel(Max)(mA) | 0.65 |
Iq per channel(Typ)(mA) | 0.55 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 2 |
Operating Temperature Range(C) | -40 to 125 0 to 70 |
Output Current(Typ)(mA) | 60 |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rail-to-Rail | In Out |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 1.6 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 6 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 2.7 |
Vn at 1kHz(Typ)(nV/rtHz) | 11 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 2 |
RoHS | Не совместим |
- Amplifiers and Bits; An Introduction to Selecting Amplifiers for Data Converters (Rev. D)PDF, 455 Кб, Версия: D, Файл опубликован: 18 май 2015
- Using the TLV246x as a Multiplexer with Gain in a Data Acquisition SystemPDF, 62 Кб, Файл опубликован: 14 дек 1998
Using the TLV246x as a multiplexer lends itself to certain applications where system signals are only measured at power up, or are measured infrequently or periodically at slow sampling rates during operation. This application report describes the circuit and discusses measurement of key parameters. - TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
- Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2460 (20)
