Datasheet Texas Instruments OPA2353UA/2K5 — Даташит
Серия | OPA2353 |
Модель | OPA2353UA/2K5 |
Высокоскоростные операционные усилители с однополярным питанием и Rail-to-Rail MicroAmplifier™ Series 8-SOIC от -40 до 85
High-Speed, Single-Supply, Rail-to-Rail Op Amps MicroAmplifier Series datasheet
PDF, 1.5 Мб, Файл опубликован: 27 сен 2000
Купить OPA2353UA/2K5 на РадиоЛоцман.Цены — от 118 до 737 ₽ 23 предложений от 16 поставщиков High-Speed, Single-Supply, ail-to- ail Operational Amplifiers MicroAmplifier(TM) Series 8-SOIC -40℃ to 85℃ | |||
OPA2353UA/2K5 Texas Instruments | 118 ₽ | ||
OPA2353UA/2K5 Texas Instruments | 130 ₽ | ||
OPA2353UA/2K5G4 Texas Instruments | 212 ₽ | ||
OPA2353UA/2K5 Texas Instruments | от 737 ₽ |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | OPA | 2353UA |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | High Cload Drive |
Архитектура | CMOS |
CMRR(Min) | 76 дБ |
CMRR(Typ) | 86 дБ |
GBW(Typ) | 44 МГц |
Input Bias Current(Max) | 10 pA |
Iq per channel(Max) | 8 мА |
Iq per channel(Typ) | 5.2 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 5 uV/C |
Output Current(Typ) | 80 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 22 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 7 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 8 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2353 (8)
