Datasheet Texas Instruments UCC28500N — Даташит
Серия | UCC28500 |
Модель | UCC28500N |
Комбинированный контроллер BiCMOS PFC/PWM 20-PDIP от -40 до 85
BiCMOS PFC/PWM Combination Controller datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 8 ноя 2001
Купить UCC28500N на РадиоЛоцман.Цены — от 295 до 2 594 ₽ 15 предложений от 11 поставщиков Power Factor Correction PWM CONTRLR 0.15mA 115kHz 20-Pin PDIP Tube | |||
UCC28500N Texas Instruments | 295 ₽ | ||
UCC28500N Texas Instruments | 408 ₽ | ||
UCC28500N | по запросу | ||
UCC28500N Texas Instruments | по запросу |
Pin | 20 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 20 |
Carrier | TUBE |
Маркировка | UCC28500N |
Width (мм) | 6.35 |
Length (мм) | 24.33 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Control Method | CCM |
Device Type | PFC+PWM |
Operating Supply Current | 4 мА |
Operating Supply(Max) | 18 В |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Peak Output Sink Current Gate Drive | 1.2 A |
Peak Output Source Current Gate Drive | -1.2 A |
Practical Operating Frequency(Max) | 0.2 МГц |
Rating | Catalog |
Special Features | Average Current Mode,Enable,OVP |
Startup Current | 0.15 мА |
UVLO Thresholds On/Off | 16/10 В |
- Evaluation Modules & Boards: UCC38500EVM
UCC38500EVM Evaluation Module
- Bootstrap Circuit for Green Mode ApplicationsPDF, 111 Кб, Файл опубликован: 27 янв 2006
- A New Synchronization Circuit for Power Converters (Rev. A)PDF, 209 Кб, Версия: A, Файл опубликован: 21 апр 2010
The synchronization of multiple PWM and PFC controllers is desirable for many reasons. The most common reason is that it keeps all the noise at one particular frequency and makes it easier to filter. The circuit described changes the slope of the ramp to lock the converter’s switching frequency to an applied signal by a phase locked loop turning it into a voltage controlled oscillator. Furthermore - Startup Current transient of the Leading Edge Triggered PFC ControllersPDF, 43 Кб, Файл опубликован: 30 июн 2004
- Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers. - DN-66 UC3854A/B and UC3855A/B Provide Power Limiting with Sinusoidal Input (Rev. A)PDF, 80 Кб, Версия: A, Файл опубликован: 6 ноя 2001
- Accurate PWM Duty Cycle ClampPDF, 58 Кб, Файл опубликован: 25 янв 2002
Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
Серия: UCC28500 (3)
- UCC28500DW UCC28500DWG4 UCC28500N
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
