Datasheet Texas Instruments LM20125MHX/NOPB — Даташит
Серия | LM20125 |
Модель | LM20125MHX/NOPB |
2,95–5,5 В, 5 А, синхронный понижающий стабилизатор тока с дополнительным автомобильным классом 16-HTSSOP от -40 до 125
LM20125/LM20125Q 5A, 500kHz PowerWise В® Synchronous Buck Regulator datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 27 мар 2013
Купить LM20125MHX/NOPB на РадиоЛоцман.Цены — от 126 до 468 ₽ 19 предложений от 12 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 5A 16-PowerTSSOP (0.173, 4.40mm Width) | |||
LM20125MHX/NOPB Texas Instruments | 126 ₽ | ||
LM20125MHX/NOPB Texas Instruments | 172 ₽ | ||
LM20125MHX/NOPB Texas Instruments | по запросу | ||
Pin | 16 | 16 |
Package Type | PWP | PWP |
Industry STD Term | HTSSOP | HTSSOP |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | MH | 20125 |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 5 | 5 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Control Mode | Current Mode |
Duty Cycle(Max) | 85 % |
Iout(Max) | 5 A |
Iq(Typ) | 3.5 мА |
Package Group | HTSSOP |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Enable,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking |
Switching Frequency(Max) | 500 kHz |
Switching Frequency(Min) | 500 kHz |
Тип | Converter |
Vin(Max) | 5.5 В |
Vin(Min) | 2.95 В |
Vout(Max) | 5 В |
Vout(Min) | 0.8 В |
- Evaluation Modules & Boards: LM20125EVAL
5A, 500kHz PowerWiseВ® Synchronous Buck Regulator Evaluation Module
- AN-2077 LM20k POL Module (Rev. A)PDF, 1.3 Мб, Версия: A, Файл опубликован: 3 май 2013
The LM20k is a full-featured synchronous buck switching regulator capable of driving up to 6A of loadcurrent and converting an input voltage between 2.95V and 5.5V down to an output voltage as low as0.8V. Fault protection features include cycle-by-cycle current limit, output power good, and output overvoltageprotection. The dual function soft-start/tracking pin can be used to control the sta - Power Supply Design Considerations for Modern FPGAs (Power Designer 121)PDF, 295 Кб, Файл опубликован: 2 фев 2010
Power Supply Design Considerations for Modern FPGAs - AN-1752 5A LM20k Reference Designs (Rev. C)PDF, 161 Кб, Версия: C, Файл опубликован: 3 май 2013
This application note discusses the design options using the high performance 5A synchronous buckconverters LM20125 and LM20145.
Серия: LM20125 (3)
- LM20125MH/NOPB LM20125MHE/NOPB LM20125MHX/NOPB
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
