Datasheet Texas Instruments ADS7820PB — Даташит
Серия | ADS7820 |
Модель | ADS7820PB |
12-битный КМОП аналого-цифровой преобразователь с частотой дискретизации 10 мкс 28-PDIP от -40 до 85
Datasheet
5 предложений от 5 поставщиков Аналого-цифровые преобразователи (АЦП) 12bit 10 Micro-Sec | |||
ADS7820PB | 98 258 ₽ | ||
ADS7820PB Texas Instruments | по запросу | ||
ADS7820PB | по запросу | ||
Pin | 28 |
Package Type | NT |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.73 |
Length (мм) | 35.69 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | ADS7804P |
Replacement Code | F |
RoHS | Не совместим |
- Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Interleaving Analog-to-Digital ConvertersPDF, 64 Кб, Файл опубликован: 2 окт 2000
It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
- What Designers Should Know About Data Converter DriftPDF, 95 Кб, Файл опубликован: 2 окт 2000
Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify.
Серия: ADS7820 (6)
- ADS7820P ADS7820PB ADS7820U ADS7820U/1K ADS7820UB ADS7820UB/1K
- Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
