Datasheet Texas Instruments TLV2461IP — Даташит
Серия | TLV2461 |
Модель | TLV2461IP |
Одиночный операционный усилитель малой мощности с Rail-to-Rail входом/выходом 8-PDIP от -40 до 125
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.7 Мб, Версия: J, Файл опубликован: 29 фев 2004
Купить TLV2461IP на РадиоЛоцман.Цены — от 60 до 451 ₽ 17 предложений от 13 поставщиков Single, Low Power, ail-to- ail Input/Output Operational Amplifier 8-PDIP -40℃ to 125℃ | |||
TLV2461IP Texas Instruments | 60 ₽ | ||
TLV2461IP Texas Instruments | 65 ₽ | ||
TLV2461IP Texas Instruments | 67 ₽ | ||
TLV2461IP Texas Instruments | по запросу |
Pin | 8 |
Package Type | P |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | TLV2461I |
Width (мм) | 6.35 |
Length (мм) | 9.81 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | Bipolar |
CMRR(Min) | 71 дБ |
CMRR(Typ) | 85 дБ |
GBW(Typ) | 6.4 МГц |
Input Bias Current(Max) | 14000 pA |
Iq per channel(Max) | 0.65 мА |
Iq per channel(Typ) | 0.55 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 2 uV/C |
Рабочий диапазон температур | от -40 до 125,0 до 70 C |
Output Current(Typ) | 80 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 1.6 V/us |
Total Supply Voltage(Max) | 6 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 11 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 2 мВ |
Бессвинцовая технология (Pb Free) | Да |
- Using the TLV246x as a Multiplexer with Gain in a Data Acquisition SystemPDF, 62 Кб, Файл опубликован: 14 дек 1998
Using the TLV246x as a multiplexer lends itself to certain applications where system signals are only measured at power up, or are measured infrequently or periodically at slow sampling rates during operation. This application report describes the circuit and discusses measurement of key parameters. - TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
- Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2461 (22)
