Datasheet Texas Instruments TL1454ACPWR — Даташит
Серия | TL1454A |
Модель | TL1454ACPWR |
Двухканальная схема управления с широтно-импульсной модуляцией (ШИМ) 16-TSSOP от -20 до 85
Dual-Channel Pulse-Width-Modulation (PWM) Control Circuit datasheet
PDF, 882 Кб, Версия: A, Файл опубликован: 25 сен 2002
Купить TL1454ACPWR на РадиоЛоцман.Цены — от 122 до 668 ₽ 16 предложений от 11 поставщиков DC DC Cntrlr Dual-OUT PWM DC to DC Controller 3.6V to 20V Input 16Pin TSSOP T/R | |||
TL1454ACPWR Texas Instruments | 122 ₽ | ||
TL1454ACPWR Texas Instruments | 132 ₽ | ||
TL1454ACPWR Texas Instruments | 153 ₽ | ||
TL1454ACPWR Texas Instruments | от 668 ₽ |
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | T1454A |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
- Understanding Buck Power Stages In Switchmode Power SuppliesPDF, 173 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous - Understanding Boost Power Stages In Switchmode Power SuppliesPDF, 149 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o - Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TL1454A (8)
- TL1454ACD TL1454ACDB TL1454ACDBR TL1454ACDG4 TL1454ACN TL1454ACNSR TL1454ACPW TL1454ACPWR
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Controller (External Switch)
