Datasheet Texas Instruments LM3S1162-IBZ50-A2T — Даташит
Серия | LM3S1162 |
Модель | LM3S1162-IBZ50-A2T |
Микроконтроллер Stellaris LM3S 108-NFBGA от -40 до 85
Stellaris LM3S1162 Microcontroller Data Sheet datasheet
PDF, 5.3 Мб, Версия: I, Файл опубликован: 16 июл 2014
Купить LM3S1162-IBZ50-A2T на РадиоЛоцман.Цены — от 637 до 6 654 ₽ 12 предложений от 9 поставщиков ARM® Cortex®-M3 Stellaris® ARM® Cortex®-M3S 1000 Microcontroller IC 32-Bit Single-Core 50MHz 64KB (64K x 8) FLASH 108-BGA (10x10) | |||
LM3S1162-IBZ50-A2T Texas Instruments | 637 ₽ | ||
LM3S1162-IBZ50-A2T Texas Instruments | 1 297 ₽ | ||
LM3S1162-IBZ50-A2T Texas Instruments | 1 361 ₽ | ||
LM3S1162-IBZ50-A2T Texas Instruments | по запросу |
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 108 | 108 | 108 |
Package Type | ZCR | ZCR | ZCR |
Industry STD Term | NFBGA | NFBGA | NFBGA |
JEDEC Code | S-PBGA-N | S-PBGA-N | S-PBGA-N |
Package QTY | 1000 | 1000 | 1000 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | LM3S1162 | IBZ50 | ZCR |
Width (мм) | 10 | 10 | 10 |
Length (мм) | 10 | 10 | 10 |
Thickness (мм) | .95 | .95 | .95 |
Pitch (мм) | .8 | .8 | .8 |
Max Height (мм) | 1.5 | 1.5 | 1.5 |
- Using Execute, Write/Erase Flash Protection on Stellaris MCUs Using CCS (Rev. A)PDF, 1.7 Мб, Версия: A, Файл опубликован: 15 авг 2012
Protection of code and IP in a microcontroller's Flash memory has always been an important consideration for the system designers. StellarisВ® microcontrollers feature a code protection mechanism that enables developers to protect their code and IP in the end application, while providing the flexibility to upgrade the firmware using a boot loader. This application report describes using Flash p - Programming the On-Chip Flash Memory in a Stellaris Microcontroller (AN01237)PDF, 95 Кб, Файл опубликован: 7 июл 2009
This application note provides three methods for erasing and programming Flash memory: the StellarisWare Peripheral DriverLib, software polling for completed updates, and interrupt-driven updates. - System Design Guidelines for StellarisВ® Microcontrollers В (Rev. B)PDF, 278 Кб, Версия: B, Файл опубликован: 4 фев 2013
- Using the Stellaris Microcontroller Analog-to-Digital Converter (AN01247)PDF, 170 Кб, Файл опубликован: 7 июл 2009
This application note describes ADC sampling and configuring Stellaris microcontrollers through the StellarisWare Peripheral Driver Library or through direct writes to the device's control registers. - Differences Among StellarisВ® LM3S and Tivaв„ў C Series TM4C123x MCUs (Rev. E)PDF, 162 Кб, Версия: E, Файл опубликован: 24 сен 2013
is document addresses design items to be aware of when migrating working designs among Fury-, DustDevil-, Tempest-, and Firestorm-StellarisВ® microcontrollers (MCUs) and Tivaв„ў C Series TM4C123x-class MCUs. Topics covered include both software and hardware issues as well as feature changes and enhancements. All software issues are comprehended in the Driver Library APIs. As a result, syste - Using the Stellaris Serial Flash Loader (AN01242)PDF, 120 Кб, Файл опубликован: 7 июл 2009
This application note describes how to communicate with the Stellaris serial flash loader application. - Using a 9-bit Software UART with Stellaris (AN01280)PDF, 301 Кб, Файл опубликован: 7 июл 2009
This application note describes how to extend the functionality of the standard hardware UART available on StellarisВ® microcontrollers by using the 9-bit UART add-on. - Optimizing Code Performance and Size for Stellaris Microcontrollers (AN01265)PDF, 161 Кб, Файл опубликован: 7 июл 2009
This application note provides a summary of factors that affect code performance and size for StellarisВ® microcontrollers and suggestions to improve code performance and size including example code. - StellarisВ® LM3S ADC Calibration (AN01282) (Rev. C)PDF, 127 Кб, Версия: C, Файл опубликован: 1 ноя 2012
This application report describes a method for improving the absolute accuracy of the analog-to-digital converters (ADCs) found on StellarisВ® LM3S microcontrollers. Due to inherent gain and offset errors, the absolute accuracy of the ADC is affected. The methods described in this application report can improve the absolute accuracy of the ADC results. - Migrating from Sandstorm-Class to Fury-Class Stellaris MicrocontrollersPDF, 184 Кб, Файл опубликован: 7 июл 2009
This application note provides a summary of differences between existing Sandstorm class devices and new Fury class devices in the Stellaris family of microcontrollers. - Using Stellaris MCUs Internal Flash Memory to Emulate EEPROM (AN01267)PDF, 91 Кб, Файл опубликован: 7 июл 2009
This application note describes how to emulate EEPROM using the internal Flash memory and provides an example application that uses EEPROM emulation drivers. - Software UART for Stellaris Microcontrollers (AN01270)PDF, 77 Кб, Файл опубликован: 7 июл 2009
This application note looks at implementing a software-based UART which, using general-purpose input/outputs (GPIO), allows the user to overcome hardware limitations or lack of dedicated peripherals. - ADC Oversampling Techniques for Stellaris Microcontrollers (AN01239) (Rev. A)PDF, 95 Кб, Версия: A, Файл опубликован: 8 янв 2013
Some members of the Stellaris microcontroller family have an analog-to-digital converter (ADC) module. The hardware resolution of the ADC is 10 bits; however, due to noise and other accuracy diminishing factors, the true accuracy is less than 10 bits. This application report provides a software-based oversampling technique, resulting in an improved effective number of bits (ENOB) in the conversion - Implementing RS-232 Flow Control on a Stellaris Microcontroller (AN01255)PDF, 74 Кб, Файл опубликован: 7 июл 2009
Серия: LM3S1162 (6)
- LM3S1162-EQC50-A2 LM3S1162-EQC50-A2T LM3S1162-IBZ50-A2 LM3S1162-IBZ50-A2T LM3S1162-IQC50-A2 LM3S1162-IQC50-A2T
- Semiconductors > Microcontrollers (MCU) > Performance MCUs > Control + Automation > LM3S Cortex-M3 Series
LM3S1162IBZ50A2T, LM3S1162 IBZ50 A2T
