Datasheet Texas Instruments LM3S2950-IBZ50-A2 — Даташит
Серия | LM3S2950 |
Модель | LM3S2950-IBZ50-A2 |
Микроконтроллер Stellaris LM3S 108-NFBGA от -40 до 85
Stellaris LM3S2950 Microcontroller Data Sheet datasheet
PDF, 4.8 Мб, Версия: I, Файл опубликован: 16 июл 2014
Купить LM3S2950-IBZ50-A2 на РадиоЛоцман.Цены — от 666 до 3 051 ₽ 16 предложений от 12 поставщиков ARM® Cortex®-M3 Stellaris® ARM® Cortex®-M3S 2000 Microcontroller IC 32-Bit Single-Core 50MHz 256KB (256K x 8) FLASH 108-BGA (10x10) | |||
LM3S2950-IBZ50-A2T Texas Instruments | 666 ₽ | ||
LM3S2950-IBZ50-A2 Texas Instruments | от 1 121 ₽ | ||
LM3S2950-IBZ50-A2T Texas Instruments | 1 343 ₽ | ||
LM3S2950-IBZ50-A2 Texas Instruments | по запросу |
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 108 | 108 | 108 |
Package Type | ZCR | ZCR | ZCR |
Industry STD Term | NFBGA | NFBGA | NFBGA |
JEDEC Code | S-PBGA-N | S-PBGA-N | S-PBGA-N |
Package QTY | 184 | 184 | 184 |
Маркировка | IBZ50 | ZCR | LM3S2950 |
Width (мм) | 10 | 10 | 10 |
Length (мм) | 10 | 10 | 10 |
Thickness (мм) | .95 | .95 | .95 |
Pitch (мм) | .8 | .8 | .8 |
Max Height (мм) | 1.5 | 1.5 | 1.5 |
- Using Execute, Write/Erase Flash Protection on Stellaris MCUs Using CCS (Rev. A)PDF, 1.7 Мб, Версия: A, Файл опубликован: 15 авг 2012
Protection of code and IP in a microcontroller's Flash memory has always been an important consideration for the system designers. StellarisВ® microcontrollers feature a code protection mechanism that enables developers to protect their code and IP in the end application, while providing the flexibility to upgrade the firmware using a boot loader. This application report describes using Flash p - Programming the On-Chip Flash Memory in a Stellaris Microcontroller (AN01237)PDF, 95 Кб, Файл опубликован: 7 июл 2009
This application note provides three methods for erasing and programming Flash memory: the StellarisWare Peripheral DriverLib, software polling for completed updates, and interrupt-driven updates. - System Design Guidelines for StellarisВ® Microcontrollers В (Rev. B)PDF, 278 Кб, Версия: B, Файл опубликован: 4 фев 2013
- Differences Among StellarisВ® LM3S and Tivaв„ў C Series TM4C123x MCUs (Rev. E)PDF, 162 Кб, Версия: E, Файл опубликован: 24 сен 2013
is document addresses design items to be aware of when migrating working designs among Fury-, DustDevil-, Tempest-, and Firestorm-StellarisВ® microcontrollers (MCUs) and Tivaв„ў C Series TM4C123x-class MCUs. Topics covered include both software and hardware issues as well as feature changes and enhancements. All software issues are comprehended in the Driver Library APIs. As a result, syste - Using the Stellaris Serial Flash Loader (AN01242)PDF, 120 Кб, Файл опубликован: 7 июл 2009
This application note describes how to communicate with the Stellaris serial flash loader application. - Using a 9-bit Software UART with Stellaris (AN01280)PDF, 301 Кб, Файл опубликован: 7 июл 2009
This application note describes how to extend the functionality of the standard hardware UART available on StellarisВ® microcontrollers by using the 9-bit UART add-on. - Optimizing Code Performance and Size for Stellaris Microcontrollers (AN01265)PDF, 161 Кб, Файл опубликован: 7 июл 2009
This application note provides a summary of factors that affect code performance and size for StellarisВ® microcontrollers and suggestions to improve code performance and size including example code. - Migrating from Sandstorm-Class to Fury-Class Stellaris MicrocontrollersPDF, 184 Кб, Файл опубликован: 7 июл 2009
This application note provides a summary of differences between existing Sandstorm class devices and new Fury class devices in the Stellaris family of microcontrollers. - Using Stellaris MCUs Internal Flash Memory to Emulate EEPROM (AN01267)PDF, 91 Кб, Файл опубликован: 7 июл 2009
This application note describes how to emulate EEPROM using the internal Flash memory and provides an example application that uses EEPROM emulation drivers. - Software UART for Stellaris Microcontrollers (AN01270)PDF, 77 Кб, Файл опубликован: 7 июл 2009
This application note looks at implementing a software-based UART which, using general-purpose input/outputs (GPIO), allows the user to overcome hardware limitations or lack of dedicated peripherals. - Implementing RS-232 Flow Control on a Stellaris Microcontroller (AN01255)PDF, 74 Кб, Файл опубликован: 7 июл 2009
Серия: LM3S2950 (4)
- LM3S2950-IBZ50-A2 LM3S2950-IBZ50-A2T LM3S2950-IQC50-A2 LM3S2950-IQC50-A2T
- Semiconductors > Microcontrollers (MCU) > Performance MCUs > Control + Automation > LM3S Cortex-M3 Series
LM3S2950IBZ50A2, LM3S2950 IBZ50 A2
