Datasheet LTC2633CTS8-HI8 - Linear Technology Даташит — Даташит
Наименование модели: LTC2633CTS8-HI8
Купить LTC2633CTS8-HI8 на РадиоЛоцман.Цены — от 136 до 547 ₽ 16 предложений от 12 поставщиков Микросхема: IC DAC 8BIT V-OUT TSOT23-8 | |||
LTC2633CTS8-HI8#TRMPBF Analog Devices | 136 ₽ | ||
LTC2633CTS8-HI8#TRPBF Linear Technology | 151 ₽ | ||
LTC2633CTS8-HI8#TRPBF Analog Devices | по запросу | ||
LTC2633CTS8-HI8#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Features
n
LTC2633 Dual 12-/10-/8-Bit I2C VOUT DACs with 10ppm/°C Reference Description
The LTC®2633 is a family of dual 12-, 10-, and 8-bit voltage-output DACs with an integrated, high accuracy, low drift reference in an 8-lead TSOT-23 package.
It has rail-to-rail output buffers and is guaranteed monotonic. The LTC2633-L has a full-scale output of 2.5V, and operates from a single 2.7V to 5.5V supply. The LTC2633-H has a full-scale output of 4.096V, and operates from a 4.5V to 5.5V supply. Each DAC can also operate with an external reference, which sets the full-scale output to the external reference voltage. These DACs communicate via a 2-wire I2C-compatible serial interface. The LTC2633 operates in both the standard mode (clock rate of 100kHz) and the fast mode (clock rate of 400kHz). The LTC2633 incorporates a power-on reset circuit. Options are available for reset to zero-scale, reset to mid-scale in internal reference mode, reset to mid-scale in external reference mode, or reset
- Разрешение: 8 бит
- Input Channel Type: Serial
- Data Interface: 2-Wire, I2C, Serial
- Supply Voltage Range - Analog: 4.5 В ... 5.5 В
- Ток потребления: 500 мкА
- Тип корпуса: TSOT-23
- Количество выводов: 8
LTC2633CTS8HI8, LTC2633CTS8 HI8
