Datasheet 47-20748-VT - NTE Electronics Даташит H/S 3/8IN 48" VIOT THIN — Даташит
Наименование модели: 47-20748-VT
Купить 47-20748-VT на РадиоЛоцман.Цены — от 241 до 35 445 ₽ 7 предложений от 4 поставщиков NTE ELECTRONICS 47-20748-VT HEAT SHRINK 3/8IN DIA THIN WALL VIOLET 48IN LENGTH 2:1 SHRINK RATIO | |||
47-20748-VT NTE Electronics | 241 ₽ | ||
47-20748-VT NTE Electronics | 256 ₽ | ||
47-20748-VT | от 319 ₽ | ||
4720748VT | 35 445 ₽ |
Производитель: NTE Electronics
Описание: H/S 3/8IN 48" VIOT THIN
Heat Shrink Tubing Thin Wall, 2:1 Shrink Ratio (Includes Assortment Packs)
Description: NTE's Thin Wall Heat Shrink Tubing is a high performance, multi purpose, professional grade, flexible, flame retardant, polyolefin based heat-shrinkable tubing with excellent electrical, chemical and physical properties.
This tubing is used extensively in industrial and military applications for cable and wire harnessing, strain relief, insulation, color coding, identification and protection against fluids. Specifications (EXCEPT Clear): D MIL-DTL-23053/5, Class 1 and 3, UL 224, 125°C, VWI CSA C22.2 No 198.1 Features: D Available in Black, Blue, Red, Green, Yellow, White, Clear, Brown, Grey, Orange and Violet D Also available in assorted packages Technical Data:
Properties Physical Tensile Strength Elongation at Break Longitudinal Change Water Absorption Spwecific Gravity Chemical Fungus Resistance Fluid Resistance Copper Corrosion Thermal Continuous Operating Temperature Minimum Shrink Temperature
4720748VT, 47 20748 VT
